TwinTurbo.NET: Nissan 300ZX forum - That thick bundle of cable with the heat shield around it
Subject That thick bundle of cable with the heat shield around it
Posted by Broke_as_**** on December 26, 2012 at 10:56 PM
  This message has been viewed 169 times.
In Reply To Re: Did you get the ground for the starter harness arounditfirst posted by boostlv on December 26, 2012 at 08:22 PM
Message If you pull that away from the block there will be a 1"-ish copper tab with a hole in it that should go under that bolt and ground the starter.
